zPerspector in ASP 1.1.0.30 for Nikon D800
- System_Drive: N/A
- processor: AMD Phenom 9500 x 4
- ram: 4GB
- Video Card: NVIDIA GeForce GT 610
Has anybodey (else) noticed issues with zPerspector with the most recent ASP version and very large files?
I have Nikon D800 and I've had the issue some batch output jobs taking very long time. possibly forever. I believe this only happens when I have zPerspector applied to D800 raw output batch using ASP 1.1.0.30, and when the output file size is large. I never had the issue with D700, and I am pretty sure the previous official (not Beta) ASP ran OK with my D800.
While writing this note I've had batch output for one picture ongoing for ½h or so...
Corel folks: I have submitted an error report...I'd like to update it but I have no link to it.
pekkal
pekkal
Re: zPerspector in ASP 1.1.0.30 for Nikon D800
same thing for me ( D800) with many plugins... Zframe din't work, so I switched back to previous version 1-0-1-10...
- System_Drive: N/A
- motherboard: 64bit
- processor: quad
- ram: 3GB
- Video Card: Nvidia
- sound_card: onboard
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: Eizo S2243 W
Did you update the plugins?
Trucks
Trucks
You'r right, I did'nt . Thank you, I'll try again.... But the problem remains
- motherboard: ASRock 890GX Pro3
- processor: AMD X6 1100T
- ram: 16GB
- Video Card: ATI HD6670
- sound_card: onBoard
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Samsung SyncMaster S27A850D 27"
i have the same problems with D800 RAW-Files (many crashes), so I switched back to previous version 1-0-1-10...
- System_Drive: N/A
I have the problem with arw-files and a Sony RX 100, using AfterShot vers.: 1.2.0.7 and zPerspector_2.0.1_WML. Compare my posting http://forum.corel.com/EN/viewtopic.php ... 30#p281983
- processor: Ryzen R5 3600X
hi,
sorry for the late reply!
the problem sounds indeed similar to the issues with zFrame and zShadow in the past.
but i need to check it in detail (i'll try to o this still this weekend).
i'll keep you updated...
br
tintin
br
tintin
hi,
quick update....
... i found an inconsistent piece of code that indeed could be the root cause.
i'm now about to fix it... hoping to get it done soon.
br
tintin
quick update....
br
tintin
hi,
even if it took more time than expected, i finally can offer an update of zPerspector with improved stability (please provide information if you still discover some stability problems with this plugin).
changelog:
https://dl.dropboxusercontent.com/u/804 ... ML.afzplug
br
tintin
changelog:
- stability improvement
- integration in 'asPluginManager'
br
tintin
- System_Drive: N/A
While zPerspector_v2.1.1_WML.afzplug works a lot better with batch processing, there is a bug with the grid changing the rotation, but it looks like it doesn't influence the batch result. Please see the attachment.
mh,
i did not yet notice this with my PCs. but i will check it detailed.
i'm quite sure that it is not visibe in output and also in 100% zoom it is not visible, right?
br
tintin
br
tintin
- System_Drive: N/A
I am pretty sure, it doesn't influence the jpg-output. But it is very confusing to see all the lines. I never saw this with earlier versions. If you think, I should check, I can try it with another linux pc with a different graphics adapter, but both are Nvidia. It depends on the photo and the amount of the rotation, but it could be a lot more confusing than shown with the sample.
- System_Drive: N/A
The grid can be seen in rendered photos under certain circumstances. Unfortunately I am not sure, when. It looks like, rotate doesn't influence it wiht PEF, but if you correct the 4 corners, it happens.
Edit: An Sony-ARW-file shows the grid with rotate only too!
hi,
sorry for my late reply - i have been away some days...
i could not yet reproduce the problem with my PC, but i think i know how to improve it. so will create a test version for you within the next days....
br
tintin
br
tintin
- System_Drive: N/A
Thanks a lot, if you want a sample raw-file, let me know. It happens here always, It doesn't help to set to grid to 1 from 256 (default). Changing the grid value doesn't create a visible grid. Rotation and "changing the corners" creates an ugly grid and the grid changes depending on the value. Resetting zPerspector removes the grid.
Edit: Simply enabling zPerspector with the checkbox without modifying any values shows the grid.
