The Terratec Cinergy T2 TNT adapter is not seen as a video capture equipment with DVD MovieFactory 3 TV even though it is plugged in a USB connector ?
In fact I would like to record TV MPEG stream straight on a DVD which I can immediatly read directly on my home DVD player
Who knows how to do ?
Thanks for help
DVD MovieFactory 3 TV doesn't work with Terratec Cinergy T2
Noren
No Support of Terratec Cinergy T2 with DVD MovieFactory 3TV
So, why Ulead DVD MovieFactory 3 TV is systematicaly delivered bundled with the Terratec Cinergy T2 TNT adaptor ?!!!
maddrummer3301
Some releases of MF are for the specific device.
You may have to use the option "Change Capture Plugin"
and see if your capture device is listed in the list of capturing plugins.
To get to the "Change Capture Plugin"
Go to the Capture Screen. After the program displays no capture devices.
Click on the "Down Arrow" to display the "Advanced Settings"
Click on "Change Capture Plugin"
You should see some type of "MPEG" Capture plugin there or the actual name of your device.
If not, use the software that came with the box (manufacturers) and then
after capturing with their software open up MF3 and import the videos into MF3.
Hope this helps,
MD
Hope this helps,
MD
