picture flaring
chezza53
picture flaring
Post by chezza53 »
I finally got to capture from my dv but i find when i have made a svd the picture seems to flare when there is movement.
How do i stop this please
Post by BrianCee »
Please post the complete properties of the file you captured from your camcorder and explain in detail the steps you took to burn that file to a VCD.
chezza53
File Properties
Post by chezza53 »
Brian
File Properties are:
Video:
Format 24 Bits (720 x 576)
Compression: MPEG-2 8000kbps
Comp Rate: 30%
Frame Rate: 25000 Frames/Sec
Total Frames: 1102 Frames
Audio
Fromat LPCM Audio
Attributes: 48000Hz, Stereo.
When I have the file in timeline, I then chose The "SHARE" button,chose :create disc
I then gave it a file name, Chose save, then in output disc format chose VCD, chose next, I then just used the current menu template. From there I went to the burn page and pressed output button and made the VCD.
Please help
Cheryl
THoff
Post by THoff »
I'm not sure what you mean by flare, but the most common problem with movement is a field order discrepancy between the capture and output formats. Since analog TV signals are interlaced and displayed as two half-frames, if they are displayed in the wrong order, there will be visible tearing during horizontal movement.
Much of what was written in the topmost thread in this forum regarding recommended procedures applies to VCDs as well as DVDs.
Merlin
Post by Merlin »
Hi Cheryl,
You are capturing in a high quality dvd setting and converting to svcd, this maybe you problem.
Try changing your capture settings to svcd which in pal land would be:
video bit rate
480 x 576
1.5 Mb/sec - 2.5 Mb/sec
audio bit rate
128 - 384 kbits/sec
chezza53
Post by chezza53 »
Hi Merlin
I tried your suggestion and it works. Thank you very much.
Once I have mastered this I am going to try and do the same for my old vhs family movies, so I might need help.
Thanks once again for the help
Cheryl
