HELP NEEDED
elle_girl
HELP NEEDED
Post by elle_girl »
hey, i am so sorry to bother you but im in desperate need of some help.
i have got the "video grabber usb 2.0 external capture device"
and Ulead video studio 7.0
i was hoping anyone could help me as i have no idea how i can capture a vhs video (pal) to my computer
i hope anyone would be kind enough to help me or offer any advise
any help would be much appreciated
kindest regards
elle x
(im sorry if this is in the wrong section or has been poster b4, please forgive me :D )
(also if you could help my email address is lasstokes123@hotmail.com)
rguthrie
motherboard: MSI MAG B550 TOMAHAWK
processor: AMD Ryzen 9 5900X 120-Core Processor
ram: 64GB
Video Card: AMD Radeon RX6600 XT
Hard_Drive_Capacity: 2TB + 4TB
Monitor/Display Make & Model: ViewSonic
Post by rguthrie »
elle_girl,
Install your external capture device according to the instructions in the box. I'm assuming it uses a red, white, and yellow connector (better known as a "composite" connector) to connect to your camera. Your camera should have came with one of those to connect normally to a TV. Use that to connect to your capture device. Turn your camera on PLAY. Start VS9. Make sure your on the Capture tab and Select Capture Video. For Source, it should automatically see your device. If not select it. Choose your capture Format, either DV/AVI or MPEG. See the article Recommended Procedures for more information. As a matter of fact read that before capturing any video. Should you have more questions, don't hesitate to ask, someone here will help. ;-)
Ron G.
Post by BrianCee »
As you have a USB device Ellie I would suggest you set your capture format to MPEG or better still choose DVD so that you should have a compliant file when you come to burn your DVD.
As Ron said please keep coming back if you have more questions,
elle_girl
Post by elle_girl »
hey ppl thanks for the help you have given me, the thing is i tried to do it but it says that
"either no video capture driver is installed in this system , or no device is connected"
now it must be installed cuz in in the programme right?? :?
and as far as i can see everything is connected right (usb from comp to the red, white n yellow extentsion to the front red white n yellow connections on my combi) :shock:
im seriously confuzed, sorry people :oops:
Post by BrianCee »
Ah - hold on there Ellie
Almost without exception the front connectors on a VCR/DVD combi unit are signal IN only - to get a signal out you will need to use one of the SCART connectors on the rear I'm afraid. AND if you have one of those SCART to Phono adapters supplied with many camcorders you can't use that either as they are supplied signal IN also - you need a specific signal OUT cable or a switchable SCART adapter from your local Maplins.
