problem with samsung vpd15i camcoder 1394
Hello i'd like transfer the video from my camcoder samsung vpd 15i to my computer by firewall 1394 but i not see the video on computer i can can move forward rewind sto and play but i can't see my video and no sound so i can't record it. Is it a problem of service pack 2 window xp?
there are the pach or the new driver?
Help me!!!!
thank you
Help me!!!!
thank you
rguthrie
- motherboard: MSI MAG B550 TOMAHAWK
- processor: AMD Ryzen 9 5900X 120-Core Processor
- ram: 64GB
- Video Card: AMD Radeon RX6600 XT
- Hard_Drive_Capacity: 2TB + 4TB
- Monitor/Display Make & Model: ViewSonic
rguthrie
- ram: 64GB
michele,
Go to
http://www.microsoft.com/downloads/deta ... laylang=en
and install this MS patch. If it doesn't work let me know. There's another fix but it is more complicated.
Ron G.
Go to
Ron G.
rguthrie
- ram: 64GB
michele,
Here's how to do it:
Go to the the hidden Windows\Inf directory and copy 1394.inf to a new directory, like \1394_fix.
Before updating to SP2:
Go to Windows\system32\drivers and copy ohci1394.sys and 1394bus.sys to \1394_fix. These files have a date around august 2002, and say SP1 in their file properties.
If you already updated to SP2: the old ohci1394.sys and 1394bus.sys are found in Windows\Driver Cache\i386\sp1.cab. Copy the files from this archive into the directory \1394_fix.
Install the SP2 update, unless you already have.
Go to Windows\system32\drivers and copy these files to \1394_fix: arp1394.sys, enum1394.sys, nic1394.sys
These files are the ones from SP2. There is no need to reinstall all old FireWire drivers. Some of them haven't changed, others are for network use only.
These files are now also found in the sp2.cab, location see above.
Rename sp2.cab to sp2_dead.cab.
This is necessary, as Windows includes a nice security mechanism, which prevents worst-case-users from accidentally overwriting important driver files with older versions, or even worse, deleting them completely. So if you try to install the mix of driver files in \1394_fix, Windows will automatically install the newer files found in its sp2.cab!
Make sure that no external FireWire device is presently connected.
Go to Device Manager, FireWire controller (OHCI xxx, 1394 or similar), Properties, Driver, Driver Update. Select 'No, only this time', 'Install from a list or specific location (advanced)', click 'Next', select 'Don't search I will choose the driver to install', click 'Next', then 'Have Disk'. Now point to \1394_fix. Then continue.
Windows will now ask for the path to the file ohci1394.sys and 1394bus.sys. It wants to install the newer ones (see above). Again point to \1394_fix.
That's it. You can now go to Driver Details, and verify that all driver files are from SP2 except the ohci1394.sys and 1394bus.sys, which are from SP1. Next reboot.
Finally you can rename sp2_dead.cab back to sp2.cab. Windows will no longer try to copy the newer driver file until you do a reinstall of the FireWire controller driver. So it makes sense to activate the driver cache security mechanism again.
This should do the trick,
Ron G.
Ron G.
rguthrie
- ram: 64GB
I'm crying
Hello! This night i have try the second possibility but not function.
With videostudio 9 i can operate with camcoder so play, rew ,fwd, stop function ,when i'm in capture mode i press play ,the camcoder start but on the prewiew the screen is black and no audio. Sigh.
Thank.
Thank.
rguthrie
- ram: 64GB
i try it
Hello, i try it, if i go in "risorse computer" i see the icon samsung device but if i double click on it it say device not function.
i had prove with powerdirector 4, and pinnacle 8 but none function.
I try to reistalling video 9....
Thank a lot.
Thank a lot.
