video studio 9 - audio editing
rockin
Post by rockin »
is it possible to remove audio from a clip in the capture or edit mode
we are new to video editing so any help is greatly appreciated
thanks rockin
AFAIK, you can't do it during capture. However, it is easy in Edit mode, and you have one of two ways of doing it. First, with your video in the timeline, right-click the clip and you will get a floating menu, and you will see 'Split Audio' as one of the choices. If you select that, then you will see a new audio file against the top audio channel in the timeline view mode. That is your original audio, which you can then delete (and/or edit in a third party audio program and then reinsert) as you like. But that is full deletion. If you later want it back or part of it, that might be difficult if you have not saved it somewhere.
A perhaps safer way of not having the original audio sound, but retaining it in case you later need it, is simply to mute the clip. Again, in Edit mode, with the clip in the timeline, if you look up to the top left hand corner of screen, you will see a Tab labelled 'Video' and under that a little window set up like a digital clock (which tells you how long a clip is or allows you to vary the time of effects). Immediately below that is a small loudspeaker icon with another little window beside it with 100 in it. That is the audio control. To the immediate right of that is another speaker icon with a cross through it. Clicking on it will totally mute the original sound track. But if you later decide you want to hear part of it, then you have only to re-click the mute control, and then, if you read the manual, you can vary the volume in various parts of the clip using the rubber band that appears in the audio mode of the timeline view.
rockin
Post by rockin »
Sorry Ken,
what I meant to ask, is it possible to remove some audio from a clip, not the entire audio from a clip, is this possible as well
your help is appreciated, Joan
See my lengthy response on audio editing, using the rubber band, at http://phpbb.ulead.com.tw/EN/viewtopic. ... ubber+band
That will show you how to vary the audio throughout a clip, including down to zero in parts.
cayvman
Post by cayvman »
Ken,
I've tried to mute button and the rubber band method, however, the sound keeps coming back on a particular clip that I don't want the audio on. Is there something I'm missing?
Thanks.
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Rubber Banding
Post by Ken Veal »
Is this essay by Ken B of any help
http://phpbb.ulead.com.tw/EN/viewtopic. ... ubber+band ..............................Ken
Sorry this is the same as above !
Post by Black Lab »
Are you watching/listening in Clip or Project Mode? Changes will not be reflected in Clip Mode.
Post by Trevor Andrew »
Well I have to disagree Jeff ---- I see the changes.
Using VS 9 with Dv-avi clip.
I cut the clip into three and mute the middle section.
The sound doesn¡¦t play in either Project or Clip playback mode for the middle clip.
I tried again using an Mpeg 2 Pal video clip, the muted section does not play in Clip or Project mode.
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
For what it's worth Trevor it is exactly the same in VS x2. Both clip and project mode are muted :!:
John Mitchell
Hi John
The OP was using VS 9, but I will look into X2 with my new 20 quid version.
Post by Black Lab »
You are correct. My mistake.
It is when you are in Audio View that the changes are not reflected when in Clip Mode. Why? I don't know. :?
Ken Veal
ram: 32 GB
exit audio view
Post by Ken Veal »
What is the quickest way of getting out of the audio view mode
... ummm ... click the timeline or storyboard button??? :roll:
mitchell65
ram: 4Gb
Ken Berry wrote:... ummm ... click the timeline or storyboard button??? :roll:
Gosh, Ken your depth of knowledge never ceases to amaze :shock:
John Mitchell
