settings to match "NTSC MPEG1 (352x240 ,29.97 fps)&q
wkdurfee
Does anyone know all the settings under all three tabs in the Make Movie Manager that match the built-in "NTSC MPEG1 (352x240 ,29.97 fps)" video file format? I have tried the obvious but am still getting something different. My goal is to have a custom format that is just like the default but without audio. Thanks.
rguthrie
- motherboard: MSI MAG B550 TOMAHAWK
- processor: AMD Ryzen 9 5900X 120-Core Processor
- ram: 64GB
- Video Card: AMD Radeon RX6600 XT
- Hard_Drive_Capacity: 2TB + 4TB
- Monitor/Display Make & Model: ViewSonic
wkdurfee,
1. Go to Tools->Make Movie Manager...
2. Select New.
3. For File Format: MPEG file(*.mpg). For Template name, whatever you want. Press OK
4. On the General tab match your settings to these:
Data Track: Video Only
Frame Rate: 29.97
Frame Type: Framed-based
Frame Size: 352x240
5. On the Compression tab match your settings to these:
Media Type: MPEG-1
Video Data Rate: Constant 1150
Press OK.
That's it!
Ron G.
2. Select New.
Frame Rate: 29.97
Frame Size: 352x240
Media Type: MPEG-1
Press OK.
That's it!
Ron G.
