Input DV from firewire - Burned DVD image ghosts badly
jiminvancouver
Post by jiminvancouver »
I imported some footage from my DV video camera using the Video capture feature of Moviefactory 3 (Full). I then burned it to a DVD -R. When I played it back, the video was jerky and seemed to ghost as an image moved around. It was so jerky, I got nauseous watching it. I imported the same video to a standalone DVD recorder and did not have any problems. So it isn't my input source. The problem is either the capture or the burning process.
maddrummer3301
Post by maddrummer3301 »
If your capturing direct to Mpeg your machine may not be able to keep
up with the process (to slow).
Try capturing to DV-Type1.
Make sure the capture template is DV.
Usually Type-1, Lower Field First (Field A).
Also, make sure to set the Project Properties Dvd Compliant attributes and Fielding Properly.
Interlaced, Bottom Field First (Field A). This might be preset in MF3.
MD
