How to make a DVD movie using VS7 ?
panmahi
Post by panmahi »
I have VS 7 and a DVD Writer. I have edited and finalized my project. Now I want to know how do I make it a DVD movie. Can not burn the project using Nero directly. Is any MPEG 2 encoding reqiured ? I have CCE SP Encoder too. but I don't know how to use it with VS7. I don't see any MPEG 2 codec under vs 7 compression list. Can somebody tell me how do I go head with my project file ? The rendering procedure and all.
Panmahi
rguthrie
motherboard: MSI MAG B550 TOMAHAWK
processor: AMD Ryzen 9 5900X 120-Core Processor
ram: 64GB
Video Card: AMD Radeon RX6600 XT
Hard_Drive_Capacity: 2TB + 4TB
Monitor/Display Make & Model: ViewSonic
Post by rguthrie »
panmahi,
Please read The Recommended Procedures at http://phpbb.ulead.com.tw/EN/viewtopic. ... bb66d8563e. This should answer your most "burning" question. ;-)
If you still have some questions don't hesitate to ask. Also, I'd suggest using SEARCH as more than likely someone has asked the same question.
Ron G.
panmahi
Post by panmahi »
Thanks Ron G.
Panmahi
panmahi
Post by panmahi »
Dear Ron G,
Here are the problems I faced.
1. If you see the guide, under "EDIT PHASE" #4 Select File/project properties, click Edit and select NTSC DVD. In my case, there is no DVD options on the window. Only PAL VCD, NTSC VCD and MPEG 1are available. I don't know what is the problem. Do I need a MPEG 2 codec installed before starting ?
2. Under Burn DVD Phase #1 when I select new project the window automatically goes to my TV card and getting ready to capture. Also the menu under share window is not active. All the buttens are inactive.
I have VS 7 and I have registered my software too.
Kindly if any know please help
Panmahi
Please do not double post. You have already posted these exact questions in the top sticky thread. Please see my answer there.
