Create video in 16 x 9 PAL Widescreen
The Old Timer
Is there any way to make a video in C3D PS which would be widescreen? That is 720 x 576 (PAL) in 16 x 9 ratio.
The Old Timer
The screen where you put your entries for outputting your project to AVI's etc has a box where it says pustom ratio. This appears to be a suppling you with presets but the only thing there is 1.1 Can you set other ratio's & if so how do you do this?
I would have expected that I should be setting my project dimensions before I start, to widescreen so as to see what the results will be before as I create my latest masterpiece but I haven't seen where I can do this.
