Poor DVD quality
danderson
Poor DVD quality
Post by danderson »
Evaluating VS9 and think I'm going to like it, but am experiencing the usual problems....
Captured, edited and burned project to dvd, but quality is very poor. It's like using slowest speed on VHS tape! Obviously somethign isn't set up right, but I'm not smart enough to know what! Will I have to start over to correct?
Terry Stetler
Post by Terry Stetler »
You didn't say what export template you're using.
When exporting a DVD file or choosing MPEG encoding options for direct burning use the Custom settings dialog. This is available when exporting a video file (Custom is at the bottom of the menu) or when direct burning by entering the Project Settings/Change MPEG Settings/Customize menu from the burning page.
I use a quality of 90, 2-pass VBR encoding, 4500-5000 kbps and Dolby audio at 224 kbps for most of my projects.
Terry Stetler
rguthrie
motherboard: MSI MAG B550 TOMAHAWK
processor: AMD Ryzen 9 5900X 120-Core Processor
ram: 64GB
Video Card: AMD Radeon RX6600 XT
Hard_Drive_Capacity: 2TB + 4TB
Monitor/Display Make & Model: ViewSonic
Post by rguthrie »
Also, could you tell us how long is your video? 1 hour? 2 hours? Did you capture in MPEG or DV? What did you capture TV, VHS, miniDV?
Ron G.
jchunter
Post by jchunter »
Ron,
Follow the procedure that is recommended in the top sticky post in this forum "Avoid Problems..." This will help you get off in the right direction.
rguthrie
ram: 64GB
Post by rguthrie »
John,
Don't you mean David? ;-)
Ron G.
