Capturing from Sony Camcorders
Donna Novak
I am thinking of purchasing Ulead for videos and I was wondering if anyone has any problems capturing from DVD from Sony Handycams. Right now I am pulling my hair out using Adobe. Whenever I burn a DVD it is choppy. Thanks for your info.
lancecarr
- ram: 12GB
- Hard_Drive_Capacity: 700GB
captainzeb
I have a Sony DCR-DHC21 MiniDV camcorder. Ulead will not allow me to control the camera from the PC and hence I cannot capture from it. From the 'source' dropdown I have "Microsoft DV camera and VCR" as a choice, yet when I look at the device manager in XP, it says "Sony DV Camcorder." When I try to capture using the Microsoft choice I get the following error message, "Unexpected error. The supplied user buffer is not valid for the requested operation." I click 'OK' to close the window and a second one opens "Capturing failed. The file created is corrupt and unusable. It will be automatically deleted."
When I go to 'Video and Audio Capture Settings" the 'video input source' is blank and greyed out as is the 'TV system.' The 'audio device' and 'Input source' are not greyed out.
I have the camera connected via firewire and it is set to 'Play/Edit' mode (VCR mode). Is this the correct setting?
It would be great to be able to control the camera from Ulead and then to capture the data in that way. Am I asking for too much?
By the way, I am able to transfer the footage from my camcorder to the PC via other programs. I press "record" in their program and then "play" on the camcorder. It does work but its nothing like what ULEAD, Pinnacle, etc. are offering.
Any ideas?
Many thanks!
Any ideas?
Many thanks!
lancecarr wrote:I have a Sony HC90 and use Ulead to capture via firewire. No dropped frames, camera is contolled fine...no problems.
lancecarr
- ram: 12GB
lancecarr
- ram: 12GB
Under "Tools" "Device control" make sure the "MS 1394 Device Control" is selected.
Under "Format" on the Capture screen make sure "DV" is selected.
And under "Tools" "Change Capture Plugin" tab make sure "Ulead Direct Show Plugin" is selected.
Also make sure DV Type 1 is selected under "Options" in the Capture screen.
captainzeb
I chose MS 1394, clicked okay but it says "Unable to open the specified device. Please check if your device is ready."lancecarr wrote:Under "Tools" "Device control" make sure the "MS 1394 Device Control" is selected.
I chose DV format but it returns to AVI automatically.
Ulead direct show plugin is set.
Unable to select DV type I, likely due to the fact that AVI keeps popping up in the format field.
heinz-oz
heinz-oz
captainzeb
lancecarr
- ram: 12GB
captainzeb
lancecarr
- ram: 12GB
Well at least that shows us something! It does not seem to be the software, either, Ulead or WinDV. The problem seems to be either Windows it self doing something weird or you may have a faulty firewire (iLink) cable or a faulty capture card or, finally, the cam itself.
You could:
1. Open the computer if you have a PCI capture card just check to see that it is seated correctly on the motherboard.
2. Check that the cable itself is ok. Try another cam or take your cam to a friends place and try it. Or, try another cable.
You could:
