dropping many frames during batch capture
don roepke
Post by don roepke »
I have Video studio 7.0
using sony cam corder and fire wire
when capturing avi its dropping about one third of the frames. Same thing happens when i try to do reqular capture.
I plan on putting it on a VHS when if I ever render & get tho the export area
Never had this problem on VS4 or 6
I did a wedding a month ago for a best friend & it had he is driving me crazy for the video.
Help Please
I am having to remember the layout of VS 7. But in the Capture screen, click on the Options icon (I think it is a cogwheel about a third of the way down the left hand side of screen). When you have set the capture to DV (if you set it to AVI, it should normally re-set automatically to DV), is DV Type 1 or Type 2 encoder showing? Often, Type 2 is the default, yet this often the most problematic, especially for resource-challenged computers. :lol: If it is indeed set for Type 2, change it to Type 1, as this is the Encoder which works on most, if not all, computers.
rguthrie
motherboard: MSI MAG B550 TOMAHAWK
processor: AMD Ryzen 9 5900X 120-Core Processor
ram: 64GB
Video Card: AMD Radeon RX6600 XT
Hard_Drive_Capacity: 2TB + 4TB
Monitor/Display Make & Model: ViewSonic
Post by rguthrie »
Try this capture program. It free and very small (in other words it won't use up much resources while capturing). ;-)
http://windv.mourek.cz/
Ron G.
don roepke
to rguthrie
Downloaded and same junpy stuff
I am using DV1 and am marking avi which reverts back to DV
don roepke
To: Ken Berry
I am using DV1 and clicking on AVI, should it go back to DV? It does.
Don
I see you have a 60GB internal and a 80GB external.
Where are you capturing to?
Why an external? you can have 4 internal IDE Drives, one will obviously be your DVD Writer leaving a further 3 slots available for internal hard drives.
Although I have an external drive I would not trust it for capturing as it is linked by a USB2 cable whcih I would not consider as fast as a drive effectively plugged straight into the motherboard by way of an IDE cable.
If capturing to your 60GB internal drive, the hard drive laser is having to work that bit extra jumping about between writing your AVI file during the capture and it's other tasks of reading the program plus all the other mundane things that windows continuosly carries out (check the program manager and note how many running processes are in play - even after a re-boot without anything else running.)
rguthrie
ram: 64GB
Post by rguthrie »
Plus I'll add how much harddrive space do you have left? When is the last time you "cleaned house" and defragmented your harddrive?
Ron G.
