I hope its not too late to butt in....
oneadem wrote:The problem is that v4.0 of Ulead's Movie Factory will not allow import of MPeg video files for cutting and adding menus. I get a message that says something like not a video file or no video in file. I know darn well they are video files because I can view them in Media Player and I can open and edit them in Movie Factory v3.0SE with no problem. I just wanted some of the extended features of 4.o but if I can't open MPSs what good is it?
Bill
The "no video" error that you are receiving is because of the Key Error and Key Error means there are components not properly installer or missing. A simple reinstall could fix this but I bet you've tried that so you need to take a look into the registry for any other keys that are left.
For Hauppauge problem, well in fairness to Ulead they mentioned in the side of the box that WDM drivers are supported. I dont think Hauppauge uses WDM drivers but fortunately, Ulead released a capture plugin for Hauppauge PVR (both PCI and USB).
(Leadteks Winfast TV tuner uses WDM drivers so you do not need a capture plugin patch for this.)
For the capture plugin patch, seems you are using an activated TBYB (trial) version. Most complaints about the patch not being installed is because of the TBYB. I think you should contact Ulead TS (email) and ask for a another copy.
