transition effect
shaked
transition effect
when i add a transition effect its shows movie A but instead of movie B there is black screen, how can i fix it?
shaked
videomartin
shaked
videomartin
shaked,
be shure - it is there.
But i don't know how it is called in your (english?) version, because i use a german version.
Look for something alike "Make or create video" in the file-menu (fourth block from top) or within the helpfile
as well as in the help file under file menu commands.
In addition there exist a button in the top menu line (but only, when you have clips on the time line).
pupcoec
How did you fix the problem with the transition?
Hi Shaked
I seem to be having the same problem you initially discussed in this post, How did you fix the transition problem?
Pupcoec
Pupcoec
pupcoec,
Make sure that the end of the first video overlaps the start of the next video on tracks A and B. The transition goes in the fx track at the spot where the two videos overlap, like so:
AAAAAAAAAAAAAAAA________________AAAAAAAAAAAAAAAA
___________TTTTTT________________TTTTT___________
___________BBBBBBBBBBBBBBBBBBBBBBBBBB
Make sure the direction of the transition, A->B or B->A is set correctly.
Hope that helps.
- Ken
Hope that helps.
- Ken
pupcoec
still experiencing problem with transitions
Thanks klowther
Your reply helped me to understand transition effects better in MSP however the problem seems to be persisting. What happens is when i add a second clip to either the A or the B track and I try to preview the video it plays fine until i reach the point where the second clip should start. At this point the audio usualy continyes as normal to the end of the preview (occationaly it clicks) but the video stops and freezes on the last frame.
when I export it as a video file it plays back fine.
Please can you help
thanks
Pupcoec
Please can you help
thanks
Pupcoec
videomartin
You should be aware that transitions can play funny tricks if they are not snapped precisely to the overlap. If in doubt, zoom the timeline to frame in filmstrip mode. Also, a gap in the video of just one frame can also do some applecart upsetting, if care is not taken. Use Search|Find empty time slots to eliminate them.
pupcoec
Thanks For the help
Thanks everybody I managet to get the preview running properly. as videomartin sugested there was a problem with my preview settings, setting the preview to instant play solved this problem.
Thanks Once again
Pupcoec
Thanks Once again
Pupcoec
