Save Current Frame as Image SIZE problem
jparnold
motherboard: Gigabyte Z390 UD
ram: 16GB DDR3
Post by jparnold »
When using VideoStudio v8 and I "Capture Current Frame as Image" the image while being 720 X 576 in size is slightly squashed horizontally and there is a small black vertical bar on each side of the image saved. I then have to resize this image (I use Paint Shop Pro) so that it is returned to normal (I do this be resizing the horizontal to 768).
It seems that there is a mix up here between PAL and NTSC.
I never had this problem using VideoStudio v6.
Is there a preferences setting to fix this?
Thanks John
rguthrie
motherboard: MSI MAG B550 TOMAHAWK
processor: AMD Ryzen 9 5900X 120-Core Processor
ram: 64GB
Video Card: AMD Radeon RX6600 XT
Hard_Drive_Capacity: 2TB + 4TB
Monitor/Display Make & Model: ViewSonic
Post by rguthrie »
jparnold,
Go to File/Preferences, click the Edit tab, ensure that your Image resampling option is set to Keep aspect ratio.
Ron G.
jparnold
ram: 16GB DDR3
Post by jparnold »
The image sampling option is already set to Keep aspect ratio.
I have just tried setting it to Fit to Project size and it now seems to work correctly.
I am sure in version 6 I had it set to Keep Aspect ratio.
Thanks for the 'lead' though.
John
rguthrie
ram: 64GB
Post by rguthrie »
John,
My bad, I had it backwards! ;-)
Ron
