no audio
sysmma
no audio
I am using Moviefactory 4 that came with my Pioneer DVR-R100 internal DVD/CD writer. I tried to view a dvd movie and there is no sound. So then, I downloaded the latest patch for moviefactory 4 and executed the file but it gives me the error that I do not have 4.0 installed. Now what?
thanks
mary
thanks
mary
nanderso
Same Problem
I am also having a problem with this. I'm using DVD MovieFactory 3.5 as delivered with my Pioneer DVD writer.
maddrummer3301
Are you using the Full Version of MF4 or a special version bundled with the CD/DVD writer. Known as SE (Special Edition) version.
If you are using the Full version simply re-install on top of the existing installation. You shouldn't need to un-install and re-install.
You can also "Repair" the existing installation if it's the full version.
Also if your trying to load the video into the timeline of MF4 and there's no sound "Right-Click" on the properties and see if the audio is Dolby Audio.
Your version may not support Dolby Audio.
Hope this helps,
MD
Hope this helps,
MD
Kiy2005
No audio
Some of the functions under Movie Factory 4 are labled as SE, but the Movie Factory application is not. I guess this means Pioneer is shipping Movie Factory SE with its DVR-R100. I was trying to watch a commercial DVD movie on the Ulead DVD Player Version 2 (comes with Ulead Movie Factory). I put the DVD into the R100, XP pops a window that asks which application to use to play the DVD. I select Ulead DVD Player and click OK. The Resume option panel appears. I select no and then ok. The panel used to display the video appears along with the Player control panel. I select play, the video panel displays the video, but there's no sound. I right click on the video playing panel and a panel appears with options. There is no properties option, however. I've upgraded the DVR's firmware to 1.37 (November, 2005 version). But, the results are the same.
I've been able to burn DVD's with this package. The resulting DVD (both on -R and +R disks) play both video and sound. I'm just having problems getting the Ulead DVD Player to play commercial DVD. Any help would be appreciated.
Kiy2005
Here is a little more information on my no audio product. I start MF4 and select create DVD then select import DVD. I have the DVD that plays only the video (via the Ulead DVD Player) in the R100. I select import DVD option and after selecting a chapter, a window shows " Dolby Digital 1 channel". When I hit the play button the video and audio play. So, I would guess that the audio path in the Ulead DVD Player and the audio path in MF4 are different. Is there a preference or property parameter I can change relative to the Ulead DVD Player that will resolve this issue?
Please, I need help. Thanks.
K.
K.
maddrummer3301
Kiy2005
No Audio
Thank you for responding.
Direct Sound is checked and S/PDIF is unchecked in the DVD Player preferences under audio.
Do you have the out of the Pioneer box DVD Player or the download trial version? I've seen posting that indicate the trial version does work.
I have Windows Media Player that plays DVD off the R100. I just wanted to get the Ulead Player to work. It's a bit of a downer to think that my research into a product before purchase was inadequate.
Thank you for your assistance.
maddrummer3301
diesan
Same results- same setup
I too have a Pioneer DVR-R100 that came with the bundled software. I too am suffering the exact same results, movie playes in player ver 2.0, but no sound. I have tried WMP and get sound but no video. I then switched to a new Creative Labs SoundBlaster Audigy4 and disabled the onboard ac97 via BIOS. Still I get no sound. My games, cds, MP3s etc sound great, but no sound in the player is unfortunate. I am open to using otehr vidoe players if they will support viewing DVDs, but this is a bit furstrating. I would think that a codec for this software should be readily availible for brand name hardware like Pioneer and Creative Labs. So, I too am looking for the same answer.
diesan
more info on last post
Thought I would throw in the config is a serial ATA drive connected to a PCI card, and the only thing running on the IDE ribbon cables is the Pioneer drive attached to the ribbon cable and set in master mode (jumpers).
HammerHead
I also have the same problem with my new Pioneer DVR-110D burner/player with the Ulead software package. But I guess the package was an OEM verssion.
Here is the response I got from Ulead.
According to your version, the Dolby Digital support is not included in this version. OEM/SE versions are built specifically according to the request of the OEM partner.
Here is a post I got from Poggy.
you have to purchase the full version of MovieFactory 4. upgrade wont work because OEM versions are not qualified for upgrade
So we not knowing bought a EOM vesion of Ulead software which does not have all the bells and whisles. I guess if you want every thing to work as expected one will have to buy the whole package, Ulead MovieFactory 4. I am thinking cutting my loses and doing it. Plus I saw the Pioneer DVD player on sale for $40 now, with no software.
I guess the MovieFactory 4 Disk Creator, $99.99 is the way to go.
I might have the MovieFactory 4 Standard Edition or something like it, 49.99, which is OK. But I think I might just buy the MovieFactory 4 Disk Creator, it seem more intergrated and I would like to try to learn video editing.
Good Luck
HH
Good Luck
HH
Kiy2005
Kiy2005
No Audio
Here is the response I recieved from Pioneer Customer Support on the request to resolve this issue.
" Thank you for contacting Pioneer Electronics, Inc.
Currently, Pioneer is working with Ulead to solve this problem
Thank You,
Michael
Customer Service Representative "
I hope the resolution is to have Ulead DVD Player that Pioneer ships with their R100 play Dolby Digital audio.
If I watched only Charlie Chaplin DVD's I would not mind using their player as it stands today. but the DVD I tried to watch on the R100 was "Ray".
K.
Thank You,
Michael
K.
