Ok, VS gospel says to keep burn properties same as file properties. However, how can that be done with a captured MPEG file @ 640x480 ? When I get into the Video Save Properties, that choice isn't available so I am unable to change burn properties accordingly. Choice for "User defined" is greyed out. Is this normal?
Also - in this case - Trevor's simple tip for keeping the burn properties same as video file and Project properties seems to be non-applicable and it plain doesn't work?????? I've another question about this tip but don't want to "clutter up" this specific problem (I'll post it after someone helps me make sense of why this isn't available).
I actually didn't find this out until i noticed rendering times were much higher with these old 640x480 captures.
Now, depending upon the answer here, what would be better?
Going with the higher res (which? - 704x480 or 720x480)? Don't see how quality would improve when the original is only 640x480?
I don't see any other way except to go down in res which doesn't seem attractive at all, or use something else to create the disk?
