VS 8 crashes when adding chapters to DVD creator
pvolpe
Post by pvolpe »
HELP!!
I am wondering if anyone has any fixes for this problem.
After I have created video and want to share the video, I chose create DVD and then I enter the add chapters section. After I select 4 chapters manually, the program crashes.
I have tried with a video in MPG already and with video still in native AVI state.
I have 2 hard drives. 1 has 20GB free out of 200GB, the other has 20GB free out of 60GB. I have 1 GB ram running pentium 4 2.5 Ghz.
I have never been able to do chapters with VS9, but was able with VS8
HELP!!!
Hi pvolpe,
pvolpe wrote:After I select 4 chapters manually, the program crashes.
Is it the same 4 chapters, and same video clip? Have you tried with other video clips? Maybe try just 3 chapters to see if there might be a problem with the video.
Also does VS9 crash when you try to burn a disk, without chapters? To troubleshoot this I recommend using a DVD +-RW disk. That way you don't waste a disc if it chooses to burn it.
Do you have any other packet writing programs installed?
Are you running any programs/utilities that run in the background?
These may not be answers to you're problem, but may eliminate some possiblites, thus narrowing it down...
Happy Holidays
Merry Christmas
pvolpe
Post by pvolpe »
Thanks for reply.
I am using VS 8 not VS9 but I still have VS7 on my system.
As we speak I am trying to do the same in VS7. It IS working!!
With the same MPG file, I have added 8 chapters and the DVD is now burning. The funny thing is though that in VS 7, the size seems to be smaller than VS8 even when I try to keep the Best quality at Variable rate 8200.
With VS 8, it would show on the space line that 4.7GB will be used, in VS 7 it is showing only 4GB. I'm worried that this will affect quality.
I still shouldn't have to use VS 7 to do a DVD on a MPG file done in VS8.
I may have some things running in the background but I have tried eliminating a few without success such as the virus.
My next step was to see if there was anything I could change in any *.ini files in terms of buffers or maximum memory or hard disk space to see if that would have any impact. No success yet.
Any other suggestions?
