Player Auto Start
neumannu47
Player Auto Start
Post by neumannu47 »
How do I disable the player from automatically starting when I insert a DVD?
jcc
Post by jcc »
Is that a commercial DVD, or if it is one produced with DMF4 has it got a menu.
maddrummer3301
Post by maddrummer3301 »
There are 2 things happening when using XP and MF4.
1st - Windows XP is using the "Autoplay" feature. When you insert a CD/DVD into the drive it automatically launches the contents.
That is built-in to the Windows operating system.
2nd - MF4 installs it's own auto-launch feature. I think it's called "Monitor". You can disable that by un-installing it or through it's own software.
XP has utilites called "Tweak-UI" or something like that. You can customize the XP settings and disable/enable the autoplay feature.
Also, another trick using Windows is to "Insert the dvd into the tray" and at the sametime "HOLD DOWN THE LEFT SHIFT KEY".
Keep the shift key held down until all activity stops.
This disables the "Autoplay" feature of the operating system.
Hope this helps,
MD
neumannu47
It's Windows 2000, and all of the autoplay features are turned off. I'll look for the monitor thing. How is it uninstalled? Thanks.
