Can't fit 1.5 hour capture onto DVD
Mister Mike
Post by Mister Mike »
kebrinton wrote:At the last step where you still have an option, try 6000 instead of 8000kbps and see how that helps.
If you then burn to a DVD-RW you can test your final product without wasting a DVD.
My footage was 1 hr 42 mins. It size was 5.7 GB I changed the "Video Data Rate" from 8000 kbs to 6000 kbs. The size dropped down to 4.3 GB with the available dvd blank media at 4.4 GB. So I proceeded to burn. After a few hours of rendering I got a message that there was not enough disk space available. Did I compress correctly?
I changed the "Video Data Rate" via Change MPEG Settings in the Project Settings window. Do I need to Change the "Video Bit Rate" ? If so where do I do this?
