How long should VHS capture sessions be?
jddealer
Post by jddealer »
I want to capture vhs, edit and burn to dvd. Is it easier to edit by capuring small segements to work with then putting them together to make a longer dvd or just capturing the whole tape and then edit?
Thanks for your help.
maddrummer3301
Post by maddrummer3301 »
It depends on how much editing you want to perform.
The best method is to use a device that converts the analog video
into what's known as DV-Type 1 format.
This is the most reliable/editable frame by frame format used.
There are many devices that can convert analog to DV. The transfer
process should be using FireWire connection (also called ilink/IEEE1394).
DV-Type1 uses about 13gig for an hour of video and requires lots of disk space.
The other format is direct to Mpeg2. If recording to Mpeg2 I would transfer the whole tape to have one continuous file. Mpeg2 isn't a
reliable editing method.
If you have many VHS tapes like I do then a dvd recorder such as Panasonic or Sony is a useful tool. Immediate results when you use one
and you can import the video's from the dvd into MF3 or MF4 and
then create custom dvd's.
Hope this helps,
MD
DVDDoug
Moderator
Post by DVDDoug »
Is it easier to edit by capuring small segements to work with then putting them together to make a longer dvd or just capturing the whole tape..
It's really a matter of personal preference. If I wanted two or three 10-minute segments off a tape, I might capture them separately. If I wanted to remove commercials from a program, I'd capture the whole thing at once. It is much easier to jump-around in a digital file than to fast-forward & rewind an analog tape. (Hence, "non-linear editing!")
...like I do then a dvd recorder such as Panasonic or Sony is a useful tool.
If you already have a DVD recorder, fine. But, do not buy one for this purpose! Several users have been unable to import video from their particular DVD recorders. And DVDs are MPEG-2. Like maddrummer said, you should avoid editing MPEGs.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
