convert folder
dmz
motherboard: ASUS ROG Strix Z390-I
processor: Intel Gen 9 i7 9700K
ram: 32GB
Video Card: mobo onboard
sound_card: mobo onboard
Hard_Drive_Capacity: 6TB
Corel programs: VS 2020
convert folder
Post by dmz »
In the area where I store my captures, there seems to be a folder called convert with lots of very large mpg files in it which I did not create. Can I delete these? Can I redirect these files to the temp directory somehow?
Post by Trevor Andrew »
Afaik the convert folder is created by video studio during rendering within the Create Disc stage.
You should NOT be rendering within the ‘Create Disc’ stage.
All rendering and converting of video files should be done via Share--Create Video File.
If you do this then the ‘Convert Folder’ will not be made.
I think you can delete this folder.
There may also be a ‘Burn Folder’ created at the same time.
Read the recommended procedure from the top post.
Trevor
