Ok, I've read hours and hours about how you can use compression to determine final size (can it fit unto single layer, etc.?). But I have also seen guides which do speak about resolution. Wouldn't this be an option or do you simply focus on compression, audio type, and bitrate and stick with 720x480?
I suspect it may all depend upon your project?
Project Examples, and what are the best settings for:
1. Copy VHS tapes (movies) onto DVD:
I've read where the ideal res would be 640x480 as this is supposed to be "True 4:3". But I cannot see where VS9 has that as any option. I can't find it. Seems from 704x480 it drops way down to 352x480. Would using 704x480 be close enough to 640x480? Wouldn't that help to decrease the file size? Surely also you wouldn't need to have such high compression as 8,000? BTW, the ATI MMC software offers 640x480 as a choice. Which is better?
Settings for 2 hours onto 1 Single Layer DVD?
Settings for 4 hours onto 1 Single Layer DVD?
2. Capture Cable TV programs and burn to DVD:
Surely you don't need to have the same settings for different content. Say you are capturing cartoons for children vs something from National Geographic where you want a better res and quality?
A: Children's Cartoons (lower quality?):
B: Wildlife Programs (higher quality?):
I guess what i'm asking is what is the best way to control size but not decrease the quality too much with the above project types?
Receiving the above settings ideas from you Pros out there would be a blessing, meanwhile I'll check out the neat link to the estimator that Trevor gave in one of the threads.
Examples where i've blown it:
1. Captured important family (VHS) video but ended up with a huge MPEG file (6GB+).
2. Captured program from cable tv (original 1948 version of Oliver Twist) and it ended up 6.36GBs!! Not sure on runtime.
Would DVD Shrink be the solution to get what I've done onto a single layer dvd or would it be better to re-render through VS9/MF4 using lower compression? Which would be better quality when finished. I have rendered a large file from 7,000 to 5000 and noticed the sharpness disappeared considerably
Hopefully my profile system settings updated correctly. In case not:
ASUS P4800E-Deluxe, 3.2GHZ P4, 1GB RAM, ATI/AIW 9800 Pro Video/capture card. WD Special Edition Caviar HHDs (PATA)
Thanks for any help on this!
