Print to Tape with Sony HDR-FX1
ten18
I tried to do this for the first time tonight with no success. Device control is working fine, because the camera will start recording just fine when I start the output from MSP8. The video shows up on the computer monitor, but not on the camera's monitor. When I try to play it back, there's nothing there. I've tried printing to tape both from the timeline and from a file - same results.
I've seen other threads on this topic, but most dealt with device control issues. I'm not having that problem, but am apparently not getting a video stream back to the camera.
Has anyone else had this problem?
Have you tried Export from your file? This is a Sony-ism and I have a similar problem with my DVCAM drive. The trouble is that Sony (and to a lesser extent, Canon) have several different non-standard ways of communicating along an IEEE-1394 link and I'm told it is not possible to cater for all with all commands, as there are conflicts.
ten18
ten18
ten18
Keith:
When the text in the MSP8 Record Window is displayed (The Video Is Recording To The HDV Camcorder) my HDR-HC1 cameras' display comes on an starts recording. Your camera might be different and take a bit longer but it shouldn't.
In the MSP8 Record Window you should get buttons for the tape transport, if the buttons are greyed out there is a problem communicating with the camera if you can use the buttons to move the tape position then you should be able to record to tape.
ten18
Tyamada
I think there is an issue with the FX1. Others on this board have mentioned that Sony has not been the best when it comes to complying with 1394 standards. I think you're a bit ahead of me - I haven't yet been able to get the record window to come up. At least I can capture and edit in HDV - just thought it would be nice to roll my edited projects back to tape so we could watch them on an HD monitor. I've been able to make some pretty good quality DVD's by outputting HDV and converting that to DVD MPEG in MSP8, but it's just not the same!! I guess we'll wait for Blu-Ray!! Thanks again for the reply!!
Keith
ten18
Keith
ten18
Keith:
You might want to send an e-mail to Ulead Tech Support. From what I have read MSP7 with the HDV plugin didn't work but you are the first one to post that the FX1 dosen't, my HC1 is also made by Sony.
You might want to get a new firewire cable, I had trouble with one that would connect intermittently so I replaced it and am not having problems.
If your camera is connected properly you should see HDV IN iLINK on your cameras view screen. If you go to MSP8 Capture module the screen should display HDV OUT iLINK.
ten18
I think I will replace my firewire cable - the one I have looks kind of cheap. I'm not seeing "HDV OUT I.LINK" on the Capture screen. I also noticed that the camera does not show up in the Windows Device Manager - I would think it should show up as an "Imaging Device." Strange, because I've been able to capture video no problem, and device control seems to work OK.
Keith
ten18
Keith
ten18
With my HDR-HC1 the camera has to be in the PLAY EDIT mode to work with MSP8.
Your Camera will not show up as a Imagaging device in the Device Manager.
It will appear in the Sound, Video and Game Controllers as a A/V Tape device.
You should check your manual for the information that is displayed on your video screen or thru the eye piece. I would think you would have a indication that the iLink is connected.
