vhs to widescreen
sleeper
motherboard: Asustek M4A78T-E
processor: 3.4 GB AMD Phenom 2 X4 965
ram: 8 mb
Video Card: ATI Radeon 5800
sound_card: ATI High def audio device
Hard_Drive_Capacity: 1 tb
vhs to widescreen
Post by sleeper »
I am using a sony hc-85 camcorder. The 16:9 widescreen is on. I recorded a football game in high def on tivo and put it on a vhs tape. I capture it and burn it on a dvd and it is in 4:3 ratio. The capture properties are 4:3 from the timeline.Can I put a vhs on widescreen? If so, what am I doing wrong? I did a couple of mini tape movies from the camcorder and they are in widescreen. Any help will be greatly appreciated. thanks. I checked the forum for help first but I'm new at this so I didn't find any messages to help.
Post by Trevor Andrew »
You don’t say what format you are capturing to.
I assume that the video footage is true 16:9
You could try this.
If you are capturing to Dvd Mpeg 2 format you can change the ‘aspect ratio’ from the Options Cogwheel / video and audio capture properties / Advanced.
Also make sure that 16:9 is selected in the File / project properties
And that ‘perform non square pixel rendering’ is ticked / selected
You are best capturing from your mini camcorder to DV via Firewire connection.
Trevor
sleeper
ram: 8 mb
Post by sleeper »
trevor, thanks for the info. I will try what you suggest. I may not have the capture properties on 16:9. I'll check it out. I appreciate ;your help. sleeper
