Hello!
My problem is that VS9 splits DV capture into 4GB chunks. Capture to DV-1. VS9 patch applied.
In VS8 there was no such problem.
Option Split by scene is unchecked, I capture to NTFS partition with enough disk space.
Please help,
X.
VS9 - DV capture being split
maddrummer3301
Under "Preferences" the (F6) key the tab all the way to the right assigns
a temporary preview directory.
Is the directory that's assigned pointing to a "FAT32" partition?
If so change it to point to a NTFS partition if your operating system is on a FAT32 partition.
There is also a size assignment on the bottom (usually off by default).
I always uncheck the default setting and assign it to a NTFS partition.
And make sure your "Working Folder" is also pointing to a NTFS partition.
MD
MD
