Export crashes Movie Factory
1Ka
Post by 1Ka »
When exporting video, by right clicking on the video file, I get the occasional crash. Windows event log shows:
Faulting application dvdvr.exe, version 3.5.0.1, faulting module uvsepa.dll, version 8.0.0.0, fault address 0x00009607.
It will do it repeatedly on some video files (DVD-RAM VR files). Others on the same disc work OK. The videos are playable on the disc, anyone else have this? I'm exporting to MPEG PAL DVD format.
Karl.
(Movie Factory version 4.03, Windows x64, AMD XP 4400)
DVDDoug
Moderator
Post by DVDDoug »
...on some video files (DVD-RAM VR files). Others on the same disc work OK.
That's a pretty clear indication of a corrupt VOB file. :( Sometimes a corrupt file will play-back OK, but cause Ulead to choke.
Maybe there was a broadcast glitch, that confused the recorder's MPEG-2 encoder???
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
1Ka
Post by 1Ka »
Cheers for that Doug.
Shouldn't MF be able to handle this without crashing? A simple programming 'catch all' around the export code would do the trick!
Having looked at the video again, MF definitely doesn't like it as it is glitchy when playing. I put it back in my Panasonic PVR and it played ok. On a whim, I copied it to the Panasonics HDD and then back to DVD-RAM. Put the disc back in MF and it played and exported OK. Strange, perhaps the disc is dodgy or some part of the -VR format was corrupt?
Karl.
maddrummer3301
Post by maddrummer3301 »
I've had some problems if I've erased titles (videos) and then started
more recordings on the same ram-disk.
Now I reformat the dvd-ram instead of deleting the recordings.
It's a standard Panasonic recorder(-vr mode).
Hope this helps,
MD
