I have been trying to add chapters to a video file but cannot seem to find the correct menu.
I am converting .wmv files to PAL VCD Mpeg files and then adding both video files into into one project. I have read through the manual but cannot locate the Create/Edit chapters menu.
Any ideas would be greatly appreciated
Adding Chapters using VS7 Basic
JohnN
Yes it could - please check by clicking on the little question mark at top right corner of the UVS window - from the drop down choose 'about Ulead VideoStudio' if the version is quoted as being "7 SE" then you have a Special (Simplified) Edition which will not burn any discs at all - You should however be able to export an mpeg2 file which you can use in any other DVD creating/burning package you may have..
