Simple question about text
daddog
Post by daddog »
I have a hard time typing in some text then using an animation. I have to retype the text "exactly" as I did before or the text will move. I have tried to copy the text as I did the first time, but I am unable to paste it in the text title track, so I have to retype it. Is there a way to copy what you have already typed and paste it again in the title track?
Thanks in advance. :)
aka James or dd :)
MB Gigabyte GA-EP45T-UD3P
CPU Intel 2 Duo E8500 3.16GHz
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
LiteOn DVD Burner SOHW-1693S
Sony HDR-CX550V camcorder
http://www.332nd.org/
GeorgeW
Post by GeorgeW »
Put your text in a regular text file in Windows. Then highlight the section, and do a COPY, then in the TEXT editor of VS9, hit CTL+V (Paste).
hth
George
Post by BrianCee »
daddog - you do not paste text into the title track - you paste it into the preview window while the cursor is flashing after you have double clicked the prompt - "Double Click here to add a title"
daddog
Post by daddog »
Ok.. I see now.
Odd it did not work with the mouse, but when I use Ctrl + V it pasted just fine. :)
Thank you gentlemen. :)
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
daddog wrote:Odd it did not work with the mouse, but when I use Ctrl + V it pasted just fine.
I work in a computer environment - in fact I am at work on nights reading this in a quiet period and I am sitting in front of 4 Computer monitors now.
Its actually quite common for programs not to have copy/paste facilities by way of a mouse click. the opposite of Ctrl-V to paste is Ctrl-C to copy.
If you use internet banking you will probably find that it will not let you use the mouse to copy/paste either, though the keyboard method will work. The banks do that as a security feature.
Regards
Steve J
daddog
Post by daddog »
Thanks Steve. :)
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
Post by Trevor Andrew »
Once you have made the first title you can reproduce other copies by :-
1 / Dragging the first title from the title track to the library.
2 / Drag the title back to the timeline.
This second title is an exact copy of the first with the text in the same position.
Change the animation to create a different effect.
Trevor
daddog
Post by daddog »
Thanks Trevor. I will try that way also! :)
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
