I'm using VideoStudio 8 to build a picture slide show.
Doing that, I notice after the ceation of the AVI video file, that some of the pictures show some vertical strips on the right side of the picture.
Any idear why that happens and what I can to to avoid this?
Regards
Martin Bordt
Strips on image/picture
bordt
The pictures are all landscape, taken directly from a digital camera.
What surprises me, that only some of the pictures show these strips.
I have created the same AVI file using the Video Editor from Ulead MediaStudio 7 - there no strips appear.
Maybe some more details about the setup:
Input files:
- JPEG, about 3000*2000
Output file:
- PAL AVI, 720*565, 16:9 format, frame based
- pictures xy relation will not be changed
System:
- Windows XP
Regards
Martin
Input files:
Output file:
System:
- Windows XP
Regards
Martin
Imiricol
bordt
Imiricol
csprick
I recently noticed the same thing - a thin vertical line about 1/3rd of the distance from the right edge of some slides in a slideshow created with VS 8. I've created quite a few other DVD's containing both video adn still photos and have not seen this happen before.
Has anyone figured out the cause / correction to this apparently random but annoying problem?
Imiricol
Yes, same problem as me, about 1/3 from the top, some are worse than others.
Like I said, I had a workaround which was to add a zoom filter at 100%, no panning, and it worked normally.
Only thing I can thing of is that I applied a patch from the ulead site a while ago, something about jpg files occasionally carrying some sort of virus. Not sure if it's related to me installing the patch, as I don't normally use still pictures in videos. I thought a jpg is a jpg, so the problem must be with VS8 itself. Hence thought it must be the patch, as it definately worked ok when I first installed the software.
Ilene
- motherboard: Thimphu intel Z 170
- processor: i7-6700K quad core
- ram: 16GB DDR4
- Video Card: 6GB NVidia GeForce GTX 980Ti
- sound_card: envy audio AV - band and olfson 5.1 channel
- Hard_Drive_Capacity: 550SSD+
- Monitor/Display Make & Model: Dell Ultra Sharp 25" 2560x1440
- Corel programs: VSX8 32 And VSX9 64 and VSX10 32
lines on jpgs
I had experienced similar problems on occasion when I was using VS9...In general I've improved my jpgs by following the following procedure....I scan the images at 200dpi...this gives me high enough resolution to zoom in, and at the same time, I reduce the image size to 720x480....you can even go with less dpi, it doesn't make too much difference. Overall the smaller image size has been helpful. I think it also improves rendering speeds because the file sizes are smaller. One other tip...I try to crop in or zoom in on the pictures even just a little. Not necessarily pan, but I crop in, so that the zoom ratio at the start of the image is the same as at the end. This along with the procedures in the opening sticky...has helped me produce clear and sharp results without the striating lines that sometimes appeared to the right of an image...both landscape an portrait.
