runtime error Pictureshow 3
zwarg
Post by zwarg »
after reformatting hard drive and loading xp pro sp2, i installed pictureshow 3. initial install failed, then successfully did a repair install.
when I attempt to open app I get the following "runtime error": "application has requested runtime to terminate it in an unusual way."
have of course done several reboots and several install attempts.
thanks in advance for your help.
cz
2log
re: runtime error Pictureshow 3
Post by 2log »
A repair alone doesn't usually solve the problem. You need to reinstall PictureShow from scratch.
When you install a software, the installer extracts temporary files needed for the installation on a temp folder. These folders are usually:
C:\Windows\Temp
C:\Documents and Settings\[User Name]\Local Settings\Temp
If the temp folder holds old installer files that may be corrupted or are duplicates with the same filename but are used for a different software, it could cause a problem for your new installation of the software. Before you reinstall the software, make sure to clean the Temp folders.
The Local Settings folder is a hidden folder so you have to enable Windows Explorer to see hidden files and folders. Open Windows Explorer, go to Tools > Folder Options > View and check show hidden files and folders. You can now open the Temp folder from the Documents and Settings folder and delete the files there before you make a new install. :wink:
"C:\Windows\Temp"
"C:\Documents and Settings\[User Name]\Local Settings\Temp"
Therefore, all the contents of these folders are no longer needed and should be cleaned regularly. If the temp folder holds old installer files that may be corrupted or are duplicates with the same filename but are used for a different software, it could cause a problem for your new installation of the software. Before you reinstall the software, make sure to clean the Temp folders.
The "Local Settings" folder is a hidden folder so you have to enable Windows Explorer to see hidden files and folders. Open "Windows Explorer", go to "Tools > Folder Options > View" and check "show hidden files and folders". You can now open the Temp folder from the "Documents and Settings" folder and delete the files there before you make a new install.
