Formatting images to fit the screen
billnchristy
Post by billnchristy »
I am attempting a stop motion video using stills. I cannot for the life of me get the format right so the picture fits in frame...can anyone please help...its the same as doing a slideshow, which i cant get to work quite right either.
jchunter_2
Post by jchunter_2 »
I would do this by cutting the video clip at the frame that you want to "freeze". Select Tools menu/"Save Current Frame as Image" - then place the image in the timeline right after the cut video clip. There really should not be an aspect ratio problem.
But if you want to force fit a still image you can set File menu/Preferences/Edit tab select Image Resampling Option = "Fit to Project Size". However, this may stretch your image. The default setting is "Keep Aspect Ratio"
billnchristy
No matter what I have tried i still get the same output....looks like a "zoom" in on my image.
At first I thought it was because it was too big, so I resized down to 640x480...no go.
Then I went to standard DVD size...no go...
Everything I am doing is still frame so I cannot grab single frames of video...
jchunter_2
Bill,
No video - so you are doing a digital slide show of stills that were shot in rapid succession? What format are the slides? When I drop 4:3 aspect ratio jpgs or bmps (e.g., 2048 x 1536) into the timeline, they resize perfectly.
billnchristy
Well, I was originally trying 640x480, my camera does upto 2560x1920, if I resize these to 4:3 (your size) you think they will work?
billnchristy
Nope, tried it and it zooms into the center of the picture...what am I doing here?
jchunter_2
Bill,
Don't resize your pictures. They are already in 4:3 aspect ratio. Just drop them into position in the timeline in their full resolution. Set your Image Resampling preferences to "Keep Aspect Ratio" before you insert.
There is a Pan and Zoom control on the left of the preview screen. Maybe you have that selected. That would make it zoom in to whatever the control is set to.
billnchristy
Still didnt work...im about ready to scrap the project...btw i have tried this with 2 other video editors and they have done the same thing.... :evil:
jchunter_2
Bill,
Right mouse on one of your still pictures and select properties. Please post every one of them in your reply.
billnchristy
data type: RGB true color 24bit
width 640
height 480
res 72 pixel/inch
size 900k
JPEG
YUV color model
size 148k
no preview
readable yes
YCbCr (YUV)
Base line encoding mode
Sampling: YUV (4:2:2)
Attributes:
JIFF no
Adobe no
Filename : DSC03749.JPG
JFIF_APP1 : Exif
Main Information
ImageDescription :
Make : SONY
Model : CYBERSHOT
DateTime : 2005:01:19 14:02:55
Sub Information
ExposureTime : 1/30Sec
FNumber : F2.4
ExposureProgram : Program Normal
ISOSpeedRatings : 320
ExifVersion : 0220
DateTimeOriginal : 2005:01:19 14:02:55
DateTimeDigitized : 2005:01:19 14:02:55
CompressedBitsPerPixel : 2/1 (bit/pixel)
ExposureBiasValue : EV0.0
MaxApertureValue : F2.0
MeteringMode : Division
LightSource : Unidentified
Flash : Not fired
FocalLength : 29.30(mm)
ExifImageWidth : 640
ExifImageHeight : 480
ExposureMode : Auto
WhiteBalance : Auto
SceneCaptureType : Standard
maddrummer3301
Post by maddrummer3301 »
Under "Preferences" referring to the "EDIT" tab
"Image resampling option" has two choices
<Keep Aspect ratio>
<Fit to Project Size>
Try reversing whatever the setting is set at.
Set Jpg to 100%
MD
jchunter_2
Bill,
Your properties indicate that you have already pre-scaled the images to 640 x 480 pixels. Perhaps whatever software you used to scale the images is at fault...
When I insert images the properties are 2048 x 1536. They show these properties when they are in the library and when they are in the timeline. Please try inserting the images raw - right out of the camera.
billnchristy
i tried that too, using pictures i had taken in the past, and in the case of the 640x480, that was done in the camera too...
Post by Trevor Andrew »
billnchristy wrote:Still didnt work...im about ready to scrap the project...btw i have tried this with 2 other video editors and they have done the same thing.... :evil:
Hi Bill
if you have used other video editors and have the same problem then i would suspect your pc set up.
just a thought
what is your pc spec'
billnchristy
2.4Ghz P4 with 1gig of ram...funny thing is, ive done 2 slideshows before...one for my daughters birthday and one for a race...i didnt have problems then...and i dont know what happened now!! I guess Ill keep on diggin...
