MaryLou, you are a saint!
I did get a response from Ulead tech support. Here is what they sent me. I'm going to study what your wrote MaryLou and then what the tech wrote. Hopefully I can find some sort of solution.
I wasn't sure what type of memory you are talking about.
Right now I have 30 free gigs of hard drive, pentium 4 processor with 2.4 mega and 512 megabytes of ram. Does this look ok?
Here is a copy of the letter from Ulead....
did a research on the error message that you are receiving and found out that this is an error that happends to any software. Right now, I can't verify if this problem is caused by the operating system or PictureShow. Let's try to uninstall and reinstall the software using the complete/clean method. Please apply the burn-fix patch after reinstalling the program. (The link of the burn patch is listed below)
Please try this clean reinstallation procedure to have it neatly installed:
1. Launch Windows Explorer and go to tools\folder option\advance setting to check "show hidden files and folders".
2. Please clean first your hard drive: Go to Start>All Programs>Accessories>System Tools then click Disk Cleanup. Choose the
system drive to clean (ususally drive C:) then click OK. Check all boxes for cleanup and then click OK to clean your hard
drive.
3. Go to your Add/Remove Programs in Control Panel and remove/uninstall PictureShow 4.
4. Go to "C:\Program Files\Ulead Systems"
5. Delete the folder for CD & DVD PictureShow 4.
6. Delete "C:\Program Files\Common Files\Ulead Systems" (***please don't delete if you have other Ulead programs installed)
7. Go to "C:\Program Files\InstallShield Installation Information". Delete the folder
"{1F6199F9-9BED-4B43-9E5C-8495086EE714}"
8. Click Start: Run: type "regedit", click Ok.
- Under HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\, please delete
{1F6199F9-9BED-4B43-9E5C-8495086EE714} folder if they are present
- Under HKEY_CURRENT_USER\Software\Ulead Systems\,please delete Ulead CD & DVD PictureShow 4 folder
- Under HKEY_LOCAL_MACHINE\Software\Ulead Systems\,please delete Ulead CD & DVD PictureShow 4 folder
9. Close regedit
10. Install CD & DVD PictureShow 4 again.
11. Download and install the link below.
Thank you and good luck!
