This is the error i get when trying to create a disk after saving my project.
the only way i can find to get around it is to create file (which is mpeg2) and takes me hours and hours, i only have a 1,8 amd over a 1 meg ram and loads of disk space) should i create maybe in another format? but will that be readable on most dvd players (not pc dvd players)
after i creat file i go CREATE DISK hours and hours later it happens
Error 4101 also when trying to create disk
- ram: 2 GB
- sound_card: Intel GMA 950
jenbo1964
Do you mean 1 GB of RAM, even my first proper PC (after upgrading from firstly a Dragon 32 to a Commodore 64) many years ago had 8 MB RAM!!!
Please update your System Specifications on your profile page,
Then please follow the advice on the following links
1. http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8959
2. http://phpbb.ulead.com.tw/EN/viewtopic.php?t=27
You should NOT be trying to burn a disc straight from a project (even though the program says you can!! Wide experience here suggests that it is probably better for most people to first use Share > Create Video File to produce a DVD-compliant mpeg-2, and then close the existing project, and go to Share > Create Disc, and use that mpeg-2 to burn the DVD. That sounds like what you are now doing, but you are only doing it as an alternative, rather than as the preferred way...
I say this because the error you received -- I think in full it reads (in bad English!) "Convert Step Got Some Problems! (4101)” Some people also received this message after applying the patch to VS9. They had to do a complete uninstall and reinstall and not apply the patch to cure the problem. I don't know if you have applied the patch.
And as sjj1805 has already indicated, we require a lot more information from you.
