Greetings all,
How does one change the setting for creating either a PAL or NTSC-compliant DVD? I installed the program and selected my region (Australia) which forces the program to use PAL... but now I've discovered the Everio cameras with the built in HD capture in NTSC, and converting between NTSC and PAL always results in inferior results. Plus I like to convert my AVI files using TMPGEnc to get higher constant bit rate data streams than produced by MovieFactory, and I encode my ac3 files separately.
How do I reselect my region for MovieFactory? Or do I have to go through the whole uninstall/install rigmarole again?
Cheers,
Ozzie
