can I change segment order?
dkmarshall
Post by dkmarshall »
Having multi-trimmed my video, I wish to change the order of the segments in the media clip list. Is this possible? I do not appear to be able to click and drag a segment to its required place.
ploggy
Post by ploggy »
you can only re-order the clips in the Add/Edit Media window. you wont be able to do that in the multi-trim video
Who? Me?
jcc
Post by jcc »
The multi-trimmed clip will need to be exported (icon to the left of the timeline). Make a note of the size of your retained sections before you do. After you re-import it into your project you can re-spilt it into it's discrete sections (scissors lower right of preview window on the Add/Edit screen). Those sections can then be re-ordered as you wish.
jcc
Post by jcc »
Another option to achieve your desired result is not to use multi-trim at all.
Use the scissors to split the clip into as many sections as required.
Delete the sections not required.
Click and drag the remaining sections into the order required.
Use CTRL+Click to select those sections to be joined into a single title and click on the Join/Separate button.
dkmarshall
Thanks for the suggestions :D
