I am trying to capture from a MiniDV tape to AVI/DV using VS9 (with update pack of 2005/08/12). Ive read the recommended procedures and done lots of reading/searching but I cant get this right.
This is the problem:
When I capture, using firewire, I choose AVI/DV Type 1. Im in NTSC country
The recommended procedures say
However I cannot choose a bitrate property in AVI format (it is an option if I try to go to MPEG direct - but my system specs are just not good enough (see below)).Set the Capture Properties
If you want the best quality and plan to burn to DVD, set a high video bitrate property (Variable, 8 Mbps) and the best frame size (720 x 480 NTSC, 720 x 576 PAL).
The very first time I did this it actually worked. I got an .avi file of about 13 GB and was able to get it onto a DVD looking fine. However, ever since, a one hour tape has recorded to 5GB, then 9GB ... and obviously the quality is terrible, producing very shaky, stuttering video and audio in the preview in edit mode (and when I run the avi file in something like Windows Media player.
I just captured 30secs as an example and here are the various settings:
Project Settings:
Microsoft AVI files
24 Bits, 720 x 480, 4:3, 29.97 fps
Lower Field First
DV Video Encoder -- type 1
Check data rate: 8000 KB/sec****
DV Audio -- NTSC, 44.100 kHz, 16 Bit, Stereo
Video Properties:
Microsoft AVI files
Lower Field First
DV Video Encoder -- type 2
Check data rate: 2173 KB/sec
PCM, 32.000 kHz, 16 Bit, Stereo
I actually got these from the info box that is asking me if I want to change the videos properties to match the video's properties.
**** I realise that above I said that I couldnt find anywhere to set the bit rate property, then in this experiment, I clicked the advanced button on the AVI tab of the project options that you get to when you click on the edit button of the Project Properties. From there I saw a check box that allowed me to 'Check data rate' - so I set that to 8000 kbps (with 0% tolerance). So the above 2 sets of properties is the first time Ive seen 'data rates'
Interestingly, the project is now at Type-2 DV, which I didnt choose.
Ive spent countless hours trying to get this to work and am on the verge of giving up. Please help.
Computer: Dell Latitude X200, Pentium III CPU-M 800Mhz 797Mhz 632 Mb RAM and 20GB free space on hard drive (very unfragmented). I turn off all other software when I do the capture to give it everything.
