I am using VS9. I made a video and rendered it. then realized that I had made a mistake in the 30 second intro. So, cut out the intro, fixed the problem and tacked the video on the end. Unfortunately, the audio is out of sync when in the project mode but not in the clip mode. I am up against a deadline. Is there a way to fix this?
Thanks,
Donna
audio sync problem in project but not in clip
Hi Donna
When you cut the intro did you edit from the original project or did you start a new project using the newly rendered file.
If you edited the project you can use the ripple effect to maintain your audio clips in position. (button to the left of the video timeline-then the link icons)
You may be better starting a new project containing your Rendered Video File and editing that.
Trevor
Trevor
