Deleteing Files
Slick
Deleteing Files
Post by Slick »
Because I work on a laptop with limited harddrive space I wish to delete all the files from a project after I burn a couple of discs. I would like to make sure I'm doing this in a complete and efficient manner. As I understand it, I must first select each clip in the library using the shift key to highlight each file indiviually, Then delete the batch of highlighted clips. Then I must go back and delete each icon which represents these individual clips. Am I doing this correctly and completly? Are there other things that need to be deleteded to clear my harddrive of a project and is there a simpler way of accomplishing this task. Thank you.
Devil
Post by Devil »
Just use Explorer to delete the contents of your video directory and the temp directory you set up in MSP. Better still, if these are in a separate partition, do a full reformat of said partition.
