PAL source video creates NTSC VR disc??
Lozzy
Post by Lozzy »
I have PAL/SECAM set in the prefs, and added a 10min PAL clip from a DVD (720x576).
If I write that out to a VR disc (DVD-RAM), it reads as an NTSC clip in my Panasonic settop player, and so doesn't play properly.
Any reason why, other than a bug??
videomartin
Post by videomartin »
Lozzy,
which version you are using ?
Did you install the updates for your DMF and the burning patches and fixes of the burning engine?
Are you shure that you get the right data stream from the other DVD?
In my knowlege DMF cannot read NTSC and convert it to PAL.
niki516
Re: PAL source video creates NTSC VR disc??
Post by niki516 »
Lozzy wrote:I have PAL/SECAM set in the prefs, and added a 10min PAL clip from a DVD (720x576).
Please check the Preference in DMF. Maybe you are having NTSC to be the TV Standard format in DMF.
Lozzy
Post by Lozzy »
videomartin wrote:Lozzy,
which version you are using ? (1)
Did you install the updates for your DMF and the burning patches and fixes of the burning engine? (2)
Are you shure that you get the right data stream from the other DVD? (3)
In my knowlege DMF cannot read NTSC and convert it to PAL (4)
1) it's version 3 disc creator
2) I have now, after much scratching of head to work out which updates I'm supposed to apply...I think it could be clearer.
3) absolutely sure :wink:
4) I agree conversion isn't possible, and yet it flagged the recording as NTSC (incorrectly) causing it to play erratically.
Thanks for all your guidance though, applying the patches and updates appears to have cured it.
Lozzy
Post by Lozzy »
niki516 wrote: Please check the Preference in DMF. Maybe you are having NTSC to be the TV Standard format in DMF.
As I said in my post, I have PAL/SECAM set in the prefs, anyway problem fixed now with updates...thanks
