Split Screen
sayer
Split Screen
Post by sayer »
Can this be done!!!
How can I remove the right hand side of
Screen, and enlarge the left hand side to Full Screen.??
on a TV Capture to MPEG
I have MF4 & MSPRO 7
Thanks Chris Sayer :oops:
You do this in Media Studio Pro using either the crop filter or you can use the Picture in Picture filter, Pan and Zoom filter or one of the other moving paths filters. Plenty to choose from.
You can add a few more to your collection here:
http://phpbb.ulead.com.tw/EN/viewtopic. ... ec94f0c10e
rguthrie
motherboard: MSI MAG B550 TOMAHAWK
processor: AMD Ryzen 9 5900X 120-Core Processor
ram: 64GB
Video Card: AMD Radeon RX6600 XT
Hard_Drive_Capacity: 2TB + 4TB
Monitor/Display Make & Model: ViewSonic
Post by rguthrie »
sayer,
I posted a tutorial on how to do this in the "VIDEO Product Tutorials" forum. It's for VideoStudio 9, but I'm sure the technique will work for MSPro as well.
Hope this helps,
Ron
Terry Stetler
Post by Terry Stetler »
Just overlap both sources (one on Va & the other on Vb) for the duration of the split screen then apply the Slide-Wipe transition. Set the first keyframe to a transition degree of 50%, copy that keyframe (context menu) and paste it to the last keyframe.
POOF!! Instant split screen.
In MSPro 8 the same idea goes, but with single track you'd literallly overlap the clips full length and use the Slide-Slide transition.
Because VideoStudio is a single track editor the procedure would be similar to that of MSPro 8.
Terry Stetler
rguthrie
ram: 64GB
Post by rguthrie »
Terry,
Using Slide-Wipe Transition won't work for VS because you can't set a transition degree or keyframe, just border, color, soft edge, and direction. However, I'm not familiar with MSPro, so I was just using my knowledge of doing the same task in VS9. ;-)
Ron
In Video Studio you could use the method outlined in my
"Video Studio Moving Path Tutorial" here:-
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8940
