opening up a dvd clip as avi in Media Pro
brydette
Sometime back I got the answer to this query but cannot find it. I need to edit a small clip from a dvd disc. I know that I rename the VOB file and give it a avi or mpg extension can someone please help as I am obviously forgetting something this job has to be done by Fri Many thanks Brian
Terry Stetler
Bargon
After you have finished with it in mediastudio...
how to use it with DVD workshop to burn a new DVD?
thanks!
thanks!
Terry Stetler
Presuming the renamed *.vob works as a proper MPEG file it should import into DVD authoring software as normal.
In DVD Workshop 2 you should un-check the box labeled "convert to disc template" on the Edit page in the presumption that the file is quite likely DVD compliant already.
I can't remember if DVD Workshop 1/1.3 had this checkbox on the Edit page or in the project settings like DVD MovieFactory.
Terry Stetler
As this is an MSP forum, if you have MSP8, you have an excellent "capture" of DVD files in Video Capture. It works vry well, whether from a non-copy-protected DVD or from DVD files on hard disk. (Also available in MF4)
Note that renaming VOBs to MPG does not always work; it depends on the content. It is not reliable as the multiplexing of audio in VOB is way different than in MPG. Even when it does work, you may have glitches. I don't recommend it.
There are also a host of DVD>MPG and DVD>AVI converters (some freebies) available on the Internet.
Terry Stetler
