How do I customise the list of Ulead Programs in the "Switch" menu of MS8Pro? At present I have 10 Ulead programs there including several which I seldom if ever use such as Cool 360 and Cool 360 viewer but Video Capture which I want to access easily from Video editor is not!
Do I have to uninstall the little used programs and MS8 and then reinstall MS8?
W2k SP4
Athlon 2800
GA-7vt-600 1394
1Gb RAM
Switching between Ulead Programs
In MSP8, you can access the Capture function directly from the VE Menu, which has a position Capture, allowing you to select video, batch or scan captures.
On my set-up, I do have the Capture function in Switch, but this may be a residue from MSP7, although it now points to MSP8
Frankly, I've no idea where the data is stored for the Switch function: I think it may not be editable without code-hacking.
David_S
- motherboard: Asus P5Q Pro
- processor: Intel Core TM 2 Quad CPU Q6600 2.4GHz
- ram: 4Gb
- Video Card: nVideo GeForce 8800 GTX
- Hard_Drive_Capacity: 4Tb
- Monitor/Display Make & Model: Philips 190B
Well I uninstalled an unused Ulead program and then reinstalled MSP8 but Video Capture did not appear in the switch menu. I uninstalled a further program and Video Editor automatically dropped it from Switch.
It would be useful to have Video Capture in "Switch" as it appears that although you can capture from the main Video Editor menu, some of the capture options can only be accessed through Video Capture.
