Can anyone help?
Just bought Movie Factory 4 and I'm trying to import from a DVD but the program crashes everytime!
Is there a fix for this?
And why oh why, if its a DVD Authoring program can't you add .VOB files?
Think this should be a minimal requirement does anyone else?
Matt
Movie Factory 4 crashes when importing DVD.
nanduhc
Re: Movie Factory 4 crashes when importing DVD.
Even I get this error:
Failed to begin VIO playback instance in the import DVD preview module. Report ID: 0x8004095a(2394)
Has anybody else got this error.
Please let me know if there is a solution. All previous versions of DVDMF have worked fine for me.
Thanks a lot for you help !!!
bigdeebb
MovieFactory crashes while importing DVD
I also get the message " Failed to begin VIO playback instance in the import DVD preview module" when I try to add a DVD-video file from a Video-TS folder. I get the button for importing the file, but when I do I get no audio from the imported file. The video also freezes after about 9 seconds of playing but the preview shows that the video is still running. What is going on?
bigdeebb
Video freezes while doing preview after importing DVD-Video
I found my problem of the video freezing while previewing a DVD-Video file could be corrected by going to Enhance Video and tobbling the Mute/Unmute once on the Audio Tab. If I do this once the file no longer freezes. If I do it again the file then again freezes after about 9 seconds. Istill go not get any audio though out of the file. The file does play audio under any other DVD playback program.
Make sure to have the latest update to MF4 installed.
http://www.ulead.com/tech/dmf/dmf_ftp.htm
The top link is for windows2000 & XP.
The 2nd link down is for win98 & Win_me.
etech
etech
bigdeebb
I still get this message when I try and import the DVD-Video file. I got rid of the freezing problem by toggling the mute button under Video Enhancement/Audio. When I toggle it again the video freezes again. This is repeatable. I also still have no audio. I tried reloading the update patch from Ulead ( I had previously installed it), but I have the same problem.
