DVD OPTION wont work
MIKELOPEZ
Post by MIKELOPEZ »
Hi guys im trying to burn a dvd in my vidoestudio 7 but when i go to creat a disk it will only give me vcd option. not a dvd ? same thing with with the creat a disk file . I can do everything except burn a dvd. can anyone help please...
Post by BrianCee »
Do you actually have version 7 Mike or do you in fact have version 7SE - if so then the DVD option may not be available to you - SE versions are all crippled in some way and some functions are not available in them.
cstoup
Post by cstoup »
I got VideoStudio SE along with the hardware I bought. I have a different problem converting to DVD, but your comment of the crippled version of SE interested me.
Do you know how I can tell what might have been removed form an SE version. In my case, the box explicitly states that it can burn DVDs, but after a week of messing around, still doesn't.
Post by BrianCee »
Unfortunately there is no definite list of what is crippled in any SE version - and there are many of them .. If it is called something like version 7SE DVD or if it came free with a DVD burner then it *should* burn DVDs - but no promises.
There are other reasons why you may not be able to burn a disc and if you explain what happens as fully as you can then hopefully someone may be able to point you in the right direction.
THoff
Post by THoff »
Check the UVS 8 program directory to see if it contains a file called DVDWizard.dll -- if it doesn't, there is no way that your version would support DVD creation.
