DVD files
maliaga
DVD files
Post by maliaga »
Hello there,
I have a camcorder that creates DVD images, I am able to import the
VIDEO_TS folder to UVS8 using the "Insert DVD/DVD-VR...", I can play
movie but I am not able to get the audio neither I can get the audio if
I use the the Share/Create disc function
I can listen to the audio i play in the camcorder or if I use PowerDVD.
Any advise will be appreicated.
Mario
Post by BrianCee »
You don't tell us what camcorder you have - is it possible it records the sound as AC-3 Dolby Digital - if it does you need the Dolby Audio plug-in which you must pay for and download from here :-
http://www.ulead.com/store/vs/runme.htm#plugin
maliaga
Hello BrianCee
Post by maliaga »
Great!! That did the trick.
I down load the software from the ULEAD site, as you indicated, It set me back $30.00 but it's worth it. I executed the code and retry it. It worked.
By the way, the Digital Video Camera Recorder is a SONY model
DCR-DVD301
Thank you so much for your advise and keep the good work!!!
