Convert step go some problems
Deon
Post by Deon »
I am running Videostudio 9, and when "Share" and create the DVD or file it runs for about 45 sec the i get the error "Convert step go some problems ( 4101 )"
Can anyone help?
Deon
A common reason for faults in the burning process is following the wrong procedure. The recommended procedure is outlined in the top sticky post on this Board. To summarise, you should NOT be going straight from the project in the timeline to the burn module (Share > Create Disc > DVD) which it sounds as though you are doing from the nature of the error message you are receiving. INSTEAD, you should use the preferred method which is to first produce a DVD-compatible mpeg-2 file (Share > Create Video File > DVD). Once you have this file, close your current project, and then click Share > Create Disc > DVD. This will open the burning module. Insert your DVD-compatible file(s). Make sure you click on 'Do not convert compliant mpeg-2 files' in the little cog-wheel icon in the bottom left of the burning module screen. Add your menu, chapters etc, and burn either the DVD itself or produce a disc image or Video_TS folder if you intend to burn more copies later.
If you are not using this method, then the wide experience here is that you are asking for trouble.
