Strobing/flickering whenI pan & zoom
micksflicks
Post by micksflicks »
I'm getting a lot of stocking/flickering when I pan & zoom on some photos.
The stop flickering filter doesn't help.
Any ideas?
Thanks in advance
Mick
THoff
Post by THoff »
Yes. Search for "field order" -- you most likely have it mixed up.
micksflicks
Could you please tell me which feild order I should be using.
Thanks again
heinz-oz
Post by heinz-oz »
It's not that hard, whatever you are using now, use the oposite and see the result. You haven't told us your project properties or anything else for that matter, how are we supposed to know which one you are or should be using?
micksflicks
Thanks for nothing
I'm sorry I'm not an arrogant expert like you & didn't know you need that information.Your help will not be needed in the future.
Thank you.
daniel
Re: Thanks for nothing
Post by daniel »
micksflicks wrote:I'm sorry I'm not an arrogant expert like you & didn't know you need that information.Your help will not be needed in the future.
Thank you.
Heinz is not an arrogant expert, he's a very helpful and respected man who's help is very welcome and has benefited numerous newbies like yourself.
(Although he sometimes shows a tendency to consider germans as non-humans? :-) )
If this forum is of no help to you you are welcome to see someplace else if you get better advice.
PS: Heinz and others, I'm not german, have no relation to germans and Germany, but believe a whole nation can't be blamed for what politicians of that country did long ago. No country has a pure and nice history.
Some admin should lock this thread that I made REALLY off-topic now...
before it goes wild with non-Ulead related answers
David G
Post by David G »
Hi micksflicks .....
do worry about heinz-oz ... I got the same acid treatment a few days ago ... I asked a similar question - see
http://phpbb.ulead.com.tw/EN/viewtopic. ... cbf105d21d
This may be of help ....
I also ran into some nice folks - sjj1805 & rwindeyer - these guys (Steve/Ron) are happier souls that gave advice ....
Hope this helps ...
DG
micksflicks
Strobing
Thanks DG.
Who & why did the person bring up the subject the German bit?
It never entered my mind.When I see the name Heinz I think soup.
I think I'll just stumble along & sort out the stobing problem my self of seek some friendly advice from Ulead direct.
Good luck in getting any help from Ulead direct. A lot of people here have no luck getting that!!
In fact, apart from his acerbic tone, Heinz was quite correct. We simply can't tell you what Field Order you should be using because we have no idea what Field Order you actually used when you experienced the strobing effect. Thus it was logical to say that you should try the opposite Field Order to the one you actually used. In other words, if you used Upper Field First, then use Lower Field First.
What we need to know are the project properties you are using for the slideshow (if indeed you are producing a slideshow).
And if it is indeed a stand-alone slideshow, you could try setting the project settings to Frame Based, as that often works best with still photos.
