I had the same problem.
Have you tried the compatibility mode as I suggested? Read other posts in the forum on the this. A simple problem. Fixed in a second
Good luck
photo express NEVER works, why?
jq_jou
the error window msg. is like this
the msg. says 'ulead phto express has encountered a problem and needs to clsoe. we are sorry for the inconvenience' 'in u r in the middle of something, the infor. u were working on might be lost' 'pls. tell microsoft aout thi problem.' 'we have created an error report that u can send to us. we will treat this report as confidential and anonymous'
jq_jou
yes, i transfered the compatibility to 'windows98/me' as sug
pasky
hi,
you might wanna try this suggestion: . Go to "Start --> All Programs --> Accessories --> Program Compatibility Wizard".
Press next then you can choose from either a list of programs or browse for it manually.
After you've chosen the Ulead software you're having problems with, go to the next step then you'll be prompted to choose another operating system.
Choose Windows 98 then click next until you finish the wizard.
Read more about this issue:
http://www.microsoft.com/technet/prodte ... xpprg.mspx
try luck folks
try luck folks
Wizentub
I have been using photo express 4 for about 5 years now, it is the one I have come to know best and rely upon above phto express 6 etc.
Over the last several months, perhaps all of this year I too have had the same problem with installing photo express 4, it kept giving out at about 70%. I cleaned the disc and everything, finally I turned off my internet connection and Boing, it worked.
I have found that I need to make sure I am not on line when I install the disc, it must be a windows update for XP or somesuch and then go back online.
I have also been having difficuloty in getting Fusion installed off the same disc to no avail.
Cheers, hope this works for you like it did for me.
jq_jou
Unfortunately, the miracle does not happen here
Thx for reply. Unfortunately, the miracle does not happen here. Trust me, i have tried every suggestion posted under this topic and none helps. I do appreciate so much inputs, meanwhile i have to say this software just sucks!
What is boing, btw?
What is boing, btw?
Wizentub
Cannot install phot ex4, Roxio interfered with instillation
Sorry my suggestion was of no Help.
Boing, is just that, like a spirng going into action, "Boing"!
One other little suggestion you may want to try, one of themessages I had eben getting with my Ulead was that thew products may not work with ROXIO CD Creator which I removed and had no other problems at all, although next time I tried to install the cd creator it just crashed like the photo express had been doing, after 6-7 goes a crack almost like a burn had formed on the disc, so you wany want to remove that programme if you have it.
Cheers and good luck with getting it to install.
